darkangel9685
- Jan 10, 2007
So, my car's stereo died. NO CD's, no radio...nothing. It was an Infinity system for a 1994 Jeep Grand Cherokee. The system was apparently the "premium" version, and thus has a separate amp (which i didn't initially know about). This is important for later.
I go and buy new stereo. It's a Sony. Bought a mounting kit as well. Total cost - $120. Not that bad, considering the same new stereo installed at a certain electronics dealer was $200. I saved $80 i though happily. I was wrong....
I go to start the install yesterday. Everything is going well. Mounting bracket (what i thought was gonna be the hardest part) went in smoothly. Old stereo came out and was disconnected easily. This took all of 15 min.
Then I get to connecting the new stereo.
First problem - different connections. Dammit!
AH! The mounting kit came with an adapter of sorts. It just needed to be spliced into the wiring for the stereo. Not so bad. I finsihed splicing in an hour or so.
I go to try it out. Radio works. CD and AUX IN, not so much. Damn, damn, damn. I'm think i messed up the wiring here, and decide to get a direct connection kit, something that has an end for sony, and and end for the jeep.
Go to big box retailer (the same one that was gonna charge me $200). Tell them what I need. End up with a wire harness that end up Sony and a "universal" connection, and another harness that ends in a Jeep connection and the "universal" connection. All is well, I think. It was dark out by now, so I'll do it tomorrow.
Tomorrow comes, and I try again. Same thing. What is going on!!??
Back to big box. Explain my situation (they were very nice about it BTW). I'm asked it the system in my Jeep is an Infinity system. Yes it is.
Well, that system has am amp. The reason why there was no CD was b/c there was no power to the amp. The connection i got for the radio was a lead for this, the Jeep end, however, does not. I'm also informed that the manufacturer does not make the connecter I need anymore.
So, I'm SOL unless I splice wires (again) for pay to have it installed. That's $90. As far as the splicing goes, I'd have to cut off the "universal" connection from the Sony side, leaving the bare wires, and cut off the connectors in the Jeep, and splice the two together.
What do I do!?
What do I do!?
