well, considering the ODAC can't do anything above 24/96, can't accept coax or optical, doesn't switch inputs, isn't balanced and I doubt sounds like a $1000 DAC, I'm not sure how you can compare them.
NOT TROLLING. JUST SCIENCE.
192K is harmful. "
192kHz digital music files offer no benefits. They're not quite neutral either; practical fidelity is slightly worse. The ultrasonics are a liability during playback.
Neither audio transducers nor power amplifiers are free of distortion, and distortion tends to increase rapidly at the lowest and highest frequencies. If the same transducer reproduces ultrasonics along with audible content, any nonlinearity will shift some of the ultrasonic content down into the audible range as an uncontrolled spray of intermodulation distortion products covering the entire audible spectrum. Nonlinearity in a power amplifier will produce the same effect. The effect is very slight, but listening tests have confirmed that both effects can be audible."--
http://people.xiph.org/~xiphmont/demo/neil-young.html
"It's worth mentioning briefly that the ear's S/N ratio is smaller than its absolute dynamic range. Within a given critical band, typical S/N is estimated to only be about 30dB. Relative S/N does not reach the full dynamic range even when considering widely spaced bands. This assures that linear 16 bit PCM offers higher resolution than is actually required.
It is also worth mentioning that increasing the bit depth of the audio representation from 16 to 24 bits does not increase the perceptible resolution or 'fineness' of the audio. It only increases the dynamic range, the range between the softest possible and the loudest possible sound, by lowering the noise floor.
However, a 16-bit noise floor is already below what we can hear"
Digital is digital.
USB = Optical = Coax. This argument is only valid if you cant physically use usb as an input, and only then and there i admit, you have a valid argument.
Now i will give a single case in point to subjectivists, and it is a
very valid point. Placebo effect is very, very real. And if you
believe something will make your audio sound better, it simply
will sound better. It doesn't matter if its a $1000 bag of rocks taped to your speakers, it
will work if you
truely believe it does.
But i
personally believe that
scientifically proven low-distortion methods of music playback
reguardless of price is the
best way to obtaining the
highest audio quality
. My placebo effect is not my wallet, but scientific charts and graphs.
