I don't know what shoul I do. Akg k712/612 Pro - gaming and media rig. / Cheap sound card + dac + amp OR expensive sound card + ? OR something like that. / Connecting everything together.
Nov 23, 2014 at 8:54 PM Thread Starter Post #1 of 15
Deagle 14mm
Hey guys,
First i want to say sorry for my English. It's not my primary language.
I want to buy headphones mostly for gaming and music. I decided to go with akg k721 pro or k612 (it depends on my budget, I'm still saving). These will by my first GOOD headphones. Unfortunately i don't know with what I should power them. I want to have CMSS-3D, and nice DD or DTS experience in movies.
I think about getting X-Fi Xtreme Audio (about 60$ in Europe) + MAGNI + MODI or X-Fi Titanium HD (200$) + (I think just amp). Whitch set up is better? What I should change? May be some other ideas?
I want to spend max 300$ on this part of rig.
And about pitting everything together.
At what should I look while buying cabels? Any specific company? Any very important specs?
Nov 24, 2014 at 1:38 AM Post #2 of 15
At what should I look while buying cables? Any specific company? Any very important specs?
What country are you in?
AKG K612 Pro headphones and Sound Blaster Z sound card should give you a good setup.
Nov 24, 2014 at 7:57 AM Post #3 of 15
I'm from Poland.
I'd rather go with K712 if I'll be able to aford it.
I've read that DACs and AMPs in sound cards can hardly compare to desktop DAC + AMP setup and sound card isn't as well isolated as desktop DAC/AMP. (am I wrong?) From sound card I only want fancy software.
And as I said before I'd like to heve CMSS-3D not SBX.
btw. Sound Blaster Z(about 100$)
Nov 24, 2014 at 2:55 PM Post #5 of 15
  I'm from Poland.
I'd rather go with K712 if I'll be able to afford it.
And as I said before I'd like to have CMSS-3D not SBX.
External DAC/Amps do offer better sound quality, then an internal sound card, but it also costs more more going external.
External DAc/amp do not come with any headphone surround sound features, like CMSS-3D or SBX, or Dolby Headphone
So you need a sound card to process the headphone surround sound and an external DAC/Amp for sound quality.
With your setup, guess it would sound card (with CMSS-3D), with an optical connection to and external DAC/amp.
The older Creative Labs Titanium series comes with CMSS-3D and the used cards will sell for around $50 (more or less).
There is the Schiit Modi/Magni DAC/Amp, $198 plus shipping and taxes.
There are some sound cards with good built in DAC features.
The Creative Labs Titanium-HD offers some really good sound quality, just connect an external headphone amplifier to it and you will have a nice setup.
Sometimes you can get a used Titanium-HD for a good price.
Usually it considered better to spend more of your audio budget for headphones, over what you spend for the DAC/amp.
You might want to figure out how much the AKG K712 will cost you, then figure out how much of your budget would be leftover for a DAC/amp and sound card.
Nov 24, 2014 at 3:38 PM Post #6 of 15
I'd go with the X-Fi Xtreme Audio and Schiit stack plus the K712.  However if you can't afford this, try the Titanium HD + Magni + K712.
Nov 24, 2014 at 4:26 PM Post #8 of 15
  Actualy first option would be cheaper for me for about 100$.
First option will also sound better, since the Schiit Modi should be a better DAC than the Titanium HD.  The X-Fi Xtreme Audio will have the same features (CMSS-3D) as the X-Fi Titanium HD.
Nov 24, 2014 at 5:08 PM Post #10 of 15
  Only software difference between X Audio and T HD in that set up would be THX if i'm reading right.
Yeah the Xtreme Audio might not have THX TruStudio Pro, which I don't think is ever worth using anyway (I have the Titanium HD).
Nov 24, 2014 at 5:48 PM Post #12 of 15
I believe the Titanium-HD's CMSS-3D uses more hardware features of the audio processor,
while the XtremeAudio's CMSS-3D's is more software based.
You really think the Modi is a noticeably better DAC then the Titanium-HD's PCM1794 DAC chip?
Nov 24, 2014 at 6:54 PM Post #13 of 15
I think the main difference would be less possible noise interference, which I've had some problems with on the Titanium HD.  But you bring up a good point about the Ti HD's CMSS-3D implementation, it's something to look into.  I don't know if they use a different X-Fi DSP, which has some of the hardware that CMSS-3D uses like X-Ram.
Nov 24, 2014 at 8:13 PM Post #14 of 15
I believe the XtremeAudio uses a audio processor from the older Audigy series (original came with EAX 3.0 or 4.0?)
While the Titanium-HD used the latest audio processor from the X-Fi series.
Getting an external DAC does removing audio noise that might be coming from inside the computer case.
but I think it comes down to what is left in his budget after buying the K712s, that dictates what he will be able to buy.
Nov 24, 2014 at 8:17 PM Post #15 of 15
I agree, the headphone is most important.
