The sensitivity tells you how much power per loudness, but not the performance.
That's great and all, but there's nothing wrong with the E9's measurable performance for the headphones you've mentioned. I'd also wager nothing wrong with subjective either if we were level matching and slapping a blindfold on someone.
Some headphones are amp dependent, such as the LCD-2 and HD800 I've just mentioned.
Where's the proof besides subjective anecdotes? I remember when people were saying the K701 is hard to drive (which is laughable, the K601 is a much more difficult load and my Mini^3 handled it just fine). Some of us are more fact and numbers driven, do you have any to support your claim?
I am not stating that E9 is cheap so therefore, it is not a good amp. I'm saying it's not a good amp.
Put your money where your mouth is. In engineering terms, what's wrong with it? This means no audiophile vocab such as "brittle, sterile, sparkle, bloat" etc. If you're saying it's a bad amp you better be able to empirically tell us why it is so.
Here, I'll even throw you a bone. The impedance on the 3.5 jack is too high, and the 1/4 jack is still high at 10 ohms. This means reactive loads below 100 ohms will probably notice a FR deviation (worth noting, planar magnetic headphones are mostly resistive so won't be effected and the HD800 impedance is too high to experience a FR deviation).
and just because it is cheap doesn't mean it is worth it. HD800 and LCD-2 are amp dependent. I suggest testing it out with various amps, and let me know if you are happy with E9.
I suggest you try them with various amps, blinded and level matched before making such claims.
Don't mind me though, I think we all have tin ears in reality.
Absolutely no problem - I'd be more than happy to sample any number of desktop amps - I'd even take the afternoon off work to do so. Comparing the E9 to amps costing 5-10 times as much is just completely unfair, but I am not about to pretend that said amps wouldnt outperform the Fiio : the question is whether they would be 5-10 times *better*.
I wouldn't assume amps costing five to ten times more would beat the Fiio. There was a guy selling amps on here not too long ago that screwed a bunch of people with expensive amps that were built wrong. SinglePower wasn't it? Furthermore, we have to bring the level of audibility into question. Is .00001% of distortion going to make an audible difference? Same with SNR and other measurable attributes.
If you told me "Hey, I have this highly reactive 30-300 ohm headphone" and were planning on using it with the E9 I'd say it's an awful idea due to the E9's output impedance . . . by all means there's better amps in such a case. The case doesn't apply to the two headphones listed though.
