watchnerd
- Jul 12, 2008
If you're saying that an up-converted file, 16/44 to 24/96 will sound exactly the same as the 16/44 file, that's the heart of the controversy.
No, that's not what I'm saying.
I'm saying 16bit vs 24bit doesn't matter if you're not doing any mastering in the digital domain.
Think of it like a vinyl rip. If I do a straight rip, no editing, it doesn't matter if it's 16bit vs 24bit. Both have enough dynamic range to cover vinyl's needs and if I I'm not doing digital editing I don't need extra bits to throw away.
In your opinion, since you do this on a weekly basis, will one of your finished HiRez 24/96 masters sound exactly the same as your finished Red Book master?
If they don't, I screwed something up!
Seriously, though, I don't even make the 16/44 version in my DAW. I save a 24/96 master copy.
By default, I make I provide a 24/96 master and a LAME V0 MP3 to the orgs I volunteer for.
I'll make a 16/44 version in SoX, not in the DAW, if someone asks for it. But most of the users seem to either want the high res version or the MP3. The boring middle ground is less popular.
How do they look on a spectrograph? Do they null each other out?
In the audible range, yes, they null.
If they don't, it means something got goofed in the down conversion / down sampling, i.e. I effed up the dither setting, usually.
[That isn't really the heart of the controversy...the heart of the controversy is whether or not recordings made in 24bits sound better than recordings made in 16bits that are upsampled to 24bits.]
That being said...
Up-converting from 16/44 to 24/96 has to sound the same (assuming your DAC isn't broken doesn't have messed up filters) as the original source unless you believe in magic. You can't magically create new data that wasn't in the original sample.
Down-converting/sampling is a different story. You can destroy things in a bad down-sample.
Prior to SoX, down conversions that weren't exact sample rate integers could be risky, i.e. 24bit/96khz to 16bit/48khz was safe, but 16bit/44.1khz was riskier. So if the down-conversion is using some old-ass software, it could be flawed.
With recent versions of SoX, this isn't an issue.
Also, bad dithering choices, or no dither at all, can jack things up when reducing bit depth.
