00940
- Nov 6, 2002
The last pages of the famous thread on ASRC have interesting stuff about the PCM1704 and BCK. http://www.diyaudio.com/forums/showt...threadid=28814
Originally Posted by audioengr You know quite a bit about hardware for a software kind of guy. I've been doing digital design for about 30 years. |
This is why my I2S implementation is so good sounding. The BCLK has very low jitter. S/PDIF implementations are not as good. You can tell the difference after about 10 seconds of listening to music. It's not subtle. Not that my S/PDIF implementations are not good, they also have very low jitter. The I2S is just better. |
Originally Posted by 00940 The last pages of the famous thread on ASRC have interesting stuff about the PCM1704 and BCK. http://www.diyaudio.com/forums/showt...threadid=28814 |
Originally Posted by thomaspf The software that I do includes drivers, clocks, protocols and measuring the outcome. Help me understand that. The I2S output from the USB audio chips are not any better than their S/PDIF outputs which is not very good. Unless you use a secondary PLL to remove the jitter from the clock line I can't quite see how that would work. |
Originally Posted by thomaspf I uderstand that the TAS1020 outputs an I2S signal I am just surprised that you think it is high quality. What is the jitter on that pin and what is the jitter when you actually drive a bclk input with that over a cable to one of the rare DACs that accept it? I am interested in your new DAC if it is stays reasonably priced. Cheers Thomas |
Originally Posted by audioengr I dont have anything resolving enough to measure it accurately. I am looking at 2-4GHz sampling scopes to replace what I have. These should have the resolution. The noise on my scope is larger than the jitter. I have two DAC's in process. The first will go head-to-head with the Cosecant. A USB TubeDAC, probably in the $3999.00 range. The first proto is in process. Still need to do front panel machining and logo etc.. Sounds awesome. Uses Siemens cca tubes from the 60's. Called the "Spoiler". The second is my long-term project, a SS USB DAC with active preamp, balanced and SE outputs, remote controlled and battery powered. Inputs are I2S, USB, S/PDIF and AES/EBU. All DC-coupled analog. This one will have the Pace Car inside. I made I2S external so it can be used with a modified Northstar 192 transport. This one is called "Formula One". Probably more than $5K. If that is all too expensive for you, then you should consider my $2650 solution. The Off-Ramp I2S coupled to a Benchmark DAC-1 with minimum mods and an I2S interface. It's a giant-killer at this price IMO. Nothing I have heard touches it. Steve N. |
Originally Posted by Konig YOur own SS design sounds like a wavelength crimson match. In headphone amps we have kevin gilmore in the SS camp and Mikhail Rotenberg in the Tube camp. Maybe in dac we will have you and gordon rankin as a parallel. |
