the reviewer neil gader stated:
""The Music Streamer HD uses high performance asynchronous USB transceiver, differential current mode conversion, and a fully differential signal path. Getting up and running is a breeze. Since it employs native Audio Class 1.0 or 2.0 drivers (available in all modern PC, Mac & Linux computers), just select the appropriate audio class via the Music Streamer HD's front panel switch, connect it to your computer via the included USB cable and connect the audio outputs to your audio system (RCA or XLR). Then select the HD as the default audio output in your computer’s audio sound preferences. LED indicators display the current sample rate (44k1, 48k, 88k2, 96k, 176k4 & 192k), the bit depth (16 or 24), and the state of the mute circuit. On my MacBook Pro I typically go into the Audio Midi setup and select the resolution I’m using. The same goes for PureMusic’s audio setup program where after selecting the sample rate I always restart the software.""
no use of win pc to verify the application of 176 192 files
