Gbjerke
- Feb 5, 2009
You can't use an external DAC with ur clip. The headphones that come with it, has no need if you're getting the Sr-80. The amp section of the IM is..nothing special. Your headphones will sound better with the T4 out of ur clip. But why won't u take advice, try your headphones with the clip and then decide if u wanna dish out for a portable amp. The difference is nothing huge. U'd get a lot more improvement upgrading into higher end grados instead of getting an amp. I'd suggest just getting an IEM for something as small as the clip already. Kind of defeats the purpose of having a tiny DAP when your headphones are big, non practical and open.
Check out the RE0
Check out the RE0
