robrob
- Jul 10, 2013
If you're not an electrical engineer and are curious about how tube amplifiers work I have a webpage dedicated to explaining them in the most non-technical method possible. The page uses guitar amplifiers but the theory is pretty much the same. If you are interested please take a look and I welcome corrections and suggestions.
https://robrobinette.com/How_Amps_Work.htm
I use the super simple Fender 5F1 Champ which uses only 26 electronic components and follow the audio signal through the layout and schematic. The schematic and layout have component numbers which match so it's easy to go between them. Every components function is explained.
