x7007
- Jun 30, 2012
I have Xonar Phoebus with DHT4 installed and Enabled with Surround Virtualizer Headphones Enabled DT990 600ohms headphones. On the Xonar Phoebus Windows Speakers it shows as 2 Channel.
How to get 5.1 and 7.1 in Movies and Games ? Should I need to set in game for example BF4 Hi-Fi and Surround ? or normal games 5.1 7.1 or just Headphones ?
In movies should I select Same as Input ? for DTS-MA movies and such DTS movies 5.1 and 7.1 what should I select to get surround ?
The Asus Xear surround makes it 7.1 Virtual Channel that you can select from the Windows speaker, it's called "Xear 7.1"
It does shows as "real" 7.1 speakers that you can test.
What exactly the Dolby Surround does ? I just can't figure if it knows to make 7.1 when Headphones/2.1 selected in games or movie player like PotPlayer or do I need to set 7.1 speakers in the games/movie player.
And what to do when using PowerDVD13 and ArcSoft Theater , they have special Audio settings and I'm totally lost.
