how to split a digital coaxial cable
Mar 26, 2006 at 6:52 AM Thread Starter Post #1 of 3
Scifiguy
I want to split the digital coaxial cable (rca) coming off my sound card so that it will go into two sources at the same time. I don't want a switch, just a y. Would a rca splitter like this work, or do I need a digital one and if so where could I find one.
Thanks.
Mar 26, 2006 at 7:24 AM Post #2 of 3
rickcr42
Are YOU talkin' to me?
Will not work and have acceptable performance
do a google on "SPDIF Distribution" to learn why
Mar 26, 2006 at 5:28 PM Post #3 of 3
sum
The only way you can get this to work is if you have pro gear with a removeable terminator. You want to make sure that there is only one 75 ohm terminator in the signal path.
