So you've still got complaints about any "recessed mids" in your D7000 after trying other implementations? It brings out recording errors in my collection that other combo's couldn't. That is detail retrieval as far as I'm concerned.
Was the question directed at me? If so, then yes, I still firmly believe that the D7000 has recessed mids. Its treble and high-mids is too artificially jacked up to create illusion of detail and air, but that's a bad way to do it--it doesn't sound natural and becomes fatiguing, especially with music that has a lot of treble energy. Even watching movies with the D7000 can sometimes get fatiguing when there's a lot of action and shouting. This only makes the recessed mids even more noticeable. I still love the D7000's bass though, but I've ordered the LCD2 and if its bass is as amazing as everyone say it is (and matches what I'd expect from its stunning frequency response graph), then I'll sell my D7000.
BTW, since you use Media Center too, you can try my EQ setting for the D7000 and you'll see how much more natural and accurate it sounds (I used Easy-Q. It's a high quality freeware):
To date, the worst I've heard the D7000 do was when I listened to the song "William, It's Really Nothing" by The Smiths. The D7000 makes that song's treble sound like a tinny, splashy, incoherent, and irritating mess. On other headphones and on my K+H O300D's, the song sounds perfectly fine. On the 007MKII, it sounds heavenly.
If you listen to the track Klendathu Drop from the Starship Troopers original score (by Basil Poledouris), or any other orchestral score with lots of strings and brass, it also become clear that the D7000's mids are recessed. Compare what the D7000 is reproducing with other headphones that are relatively much more neutral (HD650 or M50 for example) or a pair of high quality speakers, and the truth starts to hurt. Also, just listen to any guitar instrumentals--especially ones with thick and chunky distortion, and you'll hear how the "body" of those instruments are rendered to become anemic by the D7000. But with the EQ setting shown above, the D7000 does much, much better in these types of tracks.
And as I've mentioned in another thread, detail retrieval comes in two flavors--one is natural, accurate, and neutral, and the other artificially forced spotlighting of specific frequency ranges not unlike using an EQ. The artificial kind will spotlight things that were never meant to be prominent in a recording--things like lip smacks, hisses and noises...etc. Recording engineers and mixing/mastering engineers generally try to downplay those elements, and even though they allow them to stay in the recording, they don't want to draw attention to them. If a sound reproduction device is unnaturally highlighting those elements, then that's not what the recordings are supposed to sound like.
