kevinzone
- Jul 12, 2012
Hey. in headphones how do people consider how good sound stages are? I know its one thing to say a sound stage is good when you own it but how do you consider it when you dont own it
Most discussion of sound stage around here misuses the term. They confuse soundstage with phase effects. Real soundstage is a dimensional spread in front of you created by the placement of the speakers in the room, the left right placement in the stereo spread and subtle acoustic clues in the recording that create the illusion of depth.
Headphones point directly into your ears, so they can't create soundstage like speakers do. They can do an approximation with careful binaural miking, but that is a function of recording techniques, not the headphones themselves.
Another reason your question might be difficult to answer with precision is that headphone "soundstage" as is discussed around here will not exist in real space. I tend to believe that since it is created by the listener's brain and collapses to the impression of having come from inside your head if you start analysing it in real time, impressions of dimension and realism are going to be subjective. Quite sbjective. The best you can hope for is a loose concensus; measuring it in the sense of it being so wide, so deep and so high is impossible.
With speakers that can create a pinpoint image, you can observe, for instance, that a particular instrument on a particular recording seems to be three feet outside the right speaker. To demonstrate that it is still an illusion, it collapses back between the speakers when you turn to look at it. The speaker created image is still virtual but can be pointed at in real space. The image we hear in headphones does not lend itself to that level of precision, so descriptions by other listeners don't either. Individual mind/ brain combos are quite variable. No two are alike.
To nip a bogus response in the bud, notice that you need to physically turn your head to collapse some features of speaker imaging. With headphones, simply suspending your disbelief within your conciousness will collapse the image to between your ears. You might say it's the thought that counts. Factor in that most recordings now assemble artificial sound fields from isolated, close miked tracks of individual sound sources. Precision and objectivity will not be hallmarks of the perception of "headstage" by individual listeners.
Does anything actually exist to you? It seems everything you write about is created everywhere except reality.
Sure. Everything except headstage. It only exists inside your head, so I doubt there are little elves building things in there. Out in the room there is a physical dimension to things. Air is moving.
