Nak Man
- Aug 6, 2004
Memepool, personally I'm partial to 'old naks' sound such as dragon/zx9 playback to newer ones like cr7 - they sound a bit more full bodied, perhaps something to do with different pb amp used. CR7 recording, however, is almost unmatched, and as good as all manual zx9 or vintage king zxl. The real kicker for dragon is its auto azimuth correction, done very properly.
For top machines, imo the real contender to naks are revox 215 and tandberg 3014/a. Admittedly later Naks have quality problems due to the use of cheaper mechanism, and older ones suffer from capacitor problems and grease hardening. While newer models can be band aided every now and then - once you get an older nak deck fully serviced, they will last longer between maintenances.
B215s are built like tank, but recently they started to become problematic as well. Sound wise I think b215 playback is about par to cr7 quality, slightly thin compared to older naks, while its recording is also top notch. What truly separate naks from the rest are its mechanism design overkill and true discrete pb head. In this area it's very clear that naks are not a matter of preference like senn or stax of phones - it simply killed mighty Studer in cassette mechanism. Even tandberg use sandwich type pb/rec head which theoretically can't be optimised as extreme as pb and rec head on separate housings, found on all 3 head naks. The comment of tapes recorded on naks are not playable on others is a bit of exaggeration imo.
I haven't tried a 3014 yet, been contemplating a nice used one but thought I've had enough of media player that I rarely used. Had sony ES, pioneer, techics, akai and aiwa excelia before ... no comment would be better.
The worst part for naks is lack of good service and parts availability. I can still get turntable pcb part from revox (at a price =) or even b215's front faceplate (!), but try to find the correct idler rubber replacement for nak.
