arnyk
Repeatedly defended arguments with personal attacks.
- May 30, 2015
I would get the sound meter but be aware it could be off by a few dB and often are. However it should be consistently off in its measurements as long as you use the same meter on all the headphones they should end up the same. Two people with two meters and you could be way off. The down side of phone app's is keeping them calibrated in absolute SPL. They can be excellent if you have a calibrator, preamps and microphone. But that is starting at about $1k. A and C curves are both the same at 1KHz fast or slow should not matter for a sine wave but slow will average and might help be more consistent. 94dB would be a standard calibration level, but it is pretty loud might freak out people running their head phones that loud. You want to be louder then the room noise maybe 80dB is a good starting point.
As is alludged to above there is a standard kind of audio tool that is called a microphone calibrator. They are basically a tiny sound system that puts out one or two known audio tonal sounds at known frequencies at one or two different SPL levels. Some put out only one tone at one level. The point is that they do this in a highly reliable, precise and repeatable way.
The electret microphones that are commonly used for audio measurements are generally pretty stable as to their frequency response and distortion, but their sensitivity can change spontaneously due to things like temperature and humidity. Microphone calibrators thus are useful to keep track of those changes.
In modern times a measurement microphone, calibrator and mic preamp combo can be assembled for a few $100.
