SinnerG
- Nov 11, 2008
I am using a C&C XO amp which is rated for 1000mW per channel, and running a low-ish impedance set of 52 or 54mm drivers in the ATH-A900 headphones. I run the knob on around 1/4 turn.
I'm looking for another portable amp now.
Thing is, what's the deal with these super-expensive units out there that don't output more power than a soundcard or even an ipod? I'm looking at some interesting ones out there have a mere 30mW output and then there are some others which do 300mW.
I have a Asus U1 USB soundcard which outputs around 70mW and it is plenty loud, but "untidy".
The ipod shuffle is on max out to even get to a level I feel comfortable with.
How much importance do you fellow head-fiers put into the output rating of an amp along with the other specifics? Or do people not care about this rating and are simply fine running it all on a max volume setting to get them to drive large cans?
