castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
any significant evidence that most balanced amps have lower distortions that SE amps?
Not sure if this was directed toward my comments... But, why would someone suggest that balanced amps have lower distortion either?
If I replicate the same circuitry four times, how is the distortion going to be any higher or lower than the one circuit I replicated? It's the same circuit!
And I agree with you, balanced solves a problem that doesn't exist for most people. But for me, as you know, it comes down to what measures better.
The ironic part is that I'm trying to sell the only balanced amp I have... It's much larger than my SE amp, so less portable.
Sent from my E5803 using a highly trained, special forces carrier pigeon
I somehow jumped from noise to disto somewhere, dunno if that's after reading your post but it wasn't on purpose ^_^. oops
but there could be a lot to be said about both and the idea of multiplying the same circuit. we could argue that because we won't have X times the exact same components, having more will create more variations. we could argue that each component generates a noise so more components will be more noises. but of course all that would require case by case observation and there is no saying if those noises and distortions will be of any significant magnitudes compared to the values already at the output. to me that's just reassuring rant for whichever side someone picked for no good reason. if something is clearly superior, it should be easy to measure. the rest is me making glorified self justification.
