Just spend and keep what you like. No point arguing tbh. If a cheap dac gives you sound you like stick with it. If you have an expensive dac and it gives you the sound you like stick with it. Very simple. You really arent going to convince someone that thinks higher end is good or lower end has everything need that the opposite is true.
Just be happy and listen to your music as that is the most important. R2R and tubes make me very happy, but that may not be the same for others. So be it. Who cares.
