Sycraft
- Jul 6, 2004
So I broke out my PPA today after having it sit on the shelf for a long time because one of my coworkers wants to see it and run some test on it. I took the time to check it to make sure it was still in spec. All good, the outputs have 1.5mV or less DC offset, the biasing on the opamps is unchanged.
Well checking it got me to wondering about the DC offset of outputs on other things I could get my hands on like, say my soundcard in particular since that's probably one of the things that'll be used for testing. Both outputs read as above 30mV (30.4 in one case, 30.8 in the other). Ummm, is it just me or does that seem, well, high espically since this is a consumer product?
I'm pretty sure my reading is right, my metre was calibrate not too long ago.
Is that something I should be worried about driving my headphones with? I've been plugging them straight in since I don't care to buy/build an amp for work at this point. However it seems that if I did put an amp on it, I'd just be making things worse. Maybe I need to look at a non-DC amp for work.
