leo5111
- Sep 5, 2005
how much better does balanced sound vs unbalanced? for instance a Astel&Kern Ak100II with a Cayin C5 with Lcd-XC will balanced sound alot better or just a little or what?
I just wish we have 'one' port standard so you don't to deal with multiple termination costing us extra and hassle.
Higher power output. Difference in sound quality wise depends on the DAP/DAC/AMP.
I can hear from some gears too. With the correct implementation and design, it should make a differenceI heard and agree with this too. surprisingly I read somewhere that a&k do really well in SE to balanced improvements. I personally can hear a difference, it is small, but I enjoy it
There is no audible difference if you volume match.
So you think the difference is just from higher Vrms output on the port? What about the difference in Signal to Noise Ratio, THD+N and Clock Jitter?
