How loud do you listen to your headphones?
post-814899
Post #16 of 39
ampgalore
I actually measured the max volume from my car speakers. I pointed the microphone head directly against the speaker grill, was around 110 db, had no idea it could be this high. Have to turn down the volume from now on.
post-814965
Post #17 of 39
Sczervok
heh... the longer the distance from the speaker to your ear, the more you can crank it up and not feel much. I guess you found that to be dangerous eh?
post-815180
Post #18 of 39
JeffL
I think some of you are getting very INACCURATE readings.
Not to point fingers, but there is a right and wrong way to use a decibel meter. Most decibel meters are fairly accurate. The radioshack analog meter is accurate to within 2 dB, PROVIDING FOR CORRECT PLACEMENT.
SPLs difuse, just like osmosis of water. You probably learned about that in chemistry of biology. Sound can bounce around, diffuse, and is very directional.
Measuring sound directly at the speaker grill is not going to give you an accurate reading, becuase the fact is you are simply not listening at that position! You want to measure the sound from where you would normally be located in reference to the speaker. Even then, I would be very cautious of the reading.
With headphones, I would again be very wary of the measurement, and how you take it. I think some of you have grossly inaccurate measurements, either way too loud, or too quiet.
Anyway, that said, I listen around 95dB or so, but never for extended periods of time.
post-815216
Post #19 of 39
commando
AFAIK, the guys at headroom did a load of measurements, then went somewhere and learned how to do them better, so the chances of getting good results with a cheap meter are probably quite low.
post-815257
Post #20 of 39
ampgalore
Then what is the correct way to measure sound levels coming out of headphones?
I just stick the microphone next to the inner earpiece and take a measurement. Is there a better way to do it?
post-815466
Post #21 of 39
Gummy
I find I get the same amount of details even with just one click on the knob.
So I stay at the lowest volume.
I am still young, don't wanna go deaf yet.
post-815710
Post #22 of 39
h3nG
i too am interested in knowing how loud. sometimes i want to go louder, but affraid it's too loud. other time it's too loud, but i forget. wish there was an easy way to measure.
post-815739
Post #23 of 39
pbirkett
Its common sense!
Listen as loud as feels comfortable. If it feels uncomfortable, then its too loud. Resist the temptation to constantly turn it up. Simple as, IMO....
Some of you guys are almost unbelievably paranoid!
post-815749
Post #24 of 39
ampgalore
Guilty as charged!
But really, when you have a powerful amp, it makes you wonder...
post-815787
Post #25 of 39
chadbang
I would think you'd have to build an enclosure (maybe just some kind of cover), replicating the enclosure created when you press your ear against the headphone pad. When you wear a headset, you are, in a sense, creating a small listening chamber. Then I suppose you'd cut out a space for the tip of the SPL meter and take a reading inside the chamber. I think there would be a signifigant difference. More resonance and certainly a lot more pressure from bass notes.
I have no idea how the hell you'd judge a canal phone since you can barely hear a canal phone an inch away from your ear when, inserted at the same volume, it would be deafeningly loud.
And yes, it's worth worrying about. I am another Head-fier with a permanent case of tinitus from headphones. I've finally decided I'm going to have to give them up entirely.
post-815931
Post #26 of 39
doug zdanivsky
It really is common sense..
I don't mind cranking it for a few minutes for a cool song, but if it's blowing my ear drums to make it sound decent..
That's why I invested in a decent set-up.. I get the fidelity, bass response, etc I want without having it at 11 all the time..
For gaming, movies, or any other applications where there will be extended use, I go with what's comfortable. By that I mean I'll tweak it until it's too loud, then back it off..
And even then it is still way lower volume than what you're exposed to in a movie-theater, for example..
post-815949
Post #27 of 39
Xplo
I have no idea how loud I listen as I have no way to take readings.. but with all the isolation this 280 gives me, I don't need it very loud. Judging from how loud things sound in comparison when I take them off, I'd be surprised if it was over 60 dB.
post-815960
Post #28 of 39
h3nG
yeah, i am one of those paranoid people...
i mean what if what's comfortable is TOO loud?
post-815965
Post #29 of 39
Mike Scarpitti
Originally Posted by ampgalore
Just bought a radioshack SPL meter. Found out that I usually listen below 70db. How loud do you listen to your headphones?
I turn my amp up to '11'. Most amps go only to '10'.
post-816065
Post #30 of 39
lcachola
Somewhere between 70db and 80db.
