Jesse40902
- Mar 14, 2006
I want to listen to my Dap thru my speakers...thanks
Originally Posted by Jesse40902 p.s your plug in ur site is about 50 bucks...in raido shack..arent they about 10 bucks? |
Originally Posted by skyline889 Then why do Cardas, Kimber, Tara Labs, Grover, etc, make so much money? People wouldn't buy them if they didn't make a difference. There WILL be a big difference when comparing high quality interconencts to Ratshack ones, Headroom also sells some cheaper ones that are decent as well. |
Originally Posted by Jesse40902 I cant speak for audio plugs since Im new to this stuff. I know in video plugs like the component wires , it makes no differences. I tried the officalxbox component wires and the MONSTEr brand ones....it makes no differneces. The monster one is like 5x more expensive... |
Originally Posted by Jesse40902 From what I understand, the wires are thicker which just last longer. But any wire should last you for quite a while already. Im not sure abou audio though... |
Originally Posted by Blue Meanie Because people are gullible, and want to believe there is a difference. This is just my opinion. You can believe whatever you wish. Why do some folks think that Bose is the best? Because Bose tells them so... Jeff |
Originally Posted by Blue Meanie Why would a thicker wire last longer? They don't get thinner as they age... Jeff |
