If it will only be used as a transport (meaning, you intend to take a digital signal out of the FCA202) you will have a big problem:
Those are all analog connections. There is no digital output on this unit.
Originally Posted by TheShaman /img/forum/go_quote.gif Hmmm, please check this out: Behringer F-CONTROL AUDIO FCA202 Firewire (which is considered better than USB - if I'm not mistaken) and gives me balanced signal, just as I need. It also features an external power supply and it is only 85 euros (aka even cheaper than the Trends UD-10.1). Am I the only one that thinks this is a better solution that UD-10.1?! If it helps - and according to an older thread - it uses a CS4345 for D/A, CS5340 for A/D and the firewire receiver comes from TI (TSB41AB2). It will only be used as a transport. |
![FCA202_back.jpg](http://www.behringer.com//FCA202/FCA202_back.jpg)
