TheShaman
- Mar 15, 2007
Hello guys,
These are my first steps in PC-based audio and I would really like to read some suggestions from more experienced members.
Here's the story...
I have about $300-400 and I need a device (or a combination of devices) that will act both as a USB DAC from my PC to my HiFi and also as a DAC which will upgrade my CD player. In other words, this thing should come with some sort of input selection so I can choose between the two sources.
I've done my research and came up with a plan I consider pretty decent. Please, let me know what you think about it...
1) Buy a Behringer ULTRAMATCH PRO SRC2496 DAC.
2) Buy a Trends Audio UD-10.1 and use it as a USB transport
3) Connect CDplayer on the RCA (coaxial) input of SRC2496
4) Connect UD-10.1 on the XLR (AES/EBU) input of SRC2496
5) Use the input selector on the Behringer DAC to switch between PC/CDp as needed
The total cost will be around $400 (a bit less that 300 euros).
Positive points include the fact that I've heard the SRC2496 on my system and liked its sound and that it better accomodates my future plan to use a Behringer ULTRACURVE PRO DEQ2496 to better fine tune my system according to the needs of my listening room.
What do you guys think about my plan? I assume UD-10.1 will give me bit-perfect reproduction.
Is there some other device within my budget that could give me the aforementioned options and perhaps sound better? Is there any audiophile usb soundcard that can also act as a standalone DAC or, most probably, some USB DAC suitable for the task described? Forget about the room equalization thing for now if it makes things simpler.
I would really appreciate any input since my experience is considerably limited on the whole USB DAC/DAC/PC-audio subject.
Thank you in advance!
Here's the story...
