Davesrose
- Oct 20, 2006
I'll try to multi quote here just to go point by point, and I might be the last member to then give up on this.I have reread your first sentence of this post countless times and I am still having trouble understanding your point. The Bluesound post on the Node says this about “Identifying Signs of an Underpowered Drive”. Notice these are not an exhaustive list of the signs, but rather examples.
Which point here is talking about diminished audio quality with underpowered drive, or USB drive types?? Your previous link indicated that if a device isn't indexed, the effect is that it loads 500 songs per minute vs 1,000. The device emitting repeated clicking and fails to start: that's a HDD that requires external power. It may have enough juice to spin and have heads unmount, but it stops and mounts because it has not communicated to the Node. That's what the USB protocols do. There has to be a handshake with the devices. If external drives that have a DC power input are plugged in without power...they may have enough power to begin a start process, but end before there's a handshake (so again, the drive isn't recognized....let alone is recognized and can play a file). Likewise storage device does not connect or initiate: SSD drives and thumb drives don't click because they don't have physical platters. If the Node recognizes FAT32, NTFS, or ext4 (Linux file system) then it will not see a drive that's exFAT. With computers, exFAT has become a popular format for SSD since they hold some better efficiency than NTFS for the format (or if you're strictly Mac, they have a APFS system that's optimized for SSD). Also note that when I say efficient, I mean best method for fast speeds and long longevity (not some issue with faults in file transfer). Finally I'm guessing the * 500GB is enforcing the point that compatibility issues may be more so with USB 2 drives (requiring more power to operate because that standard did not have as much power in the interface).Identifying Signs of an Underpowered Drive
Indications of an underpowered drive include, but are not restricted to:
*Typically, underpowered drives have a size exceeding 500GB or 0.5TB.
- The PLAY/PAUSE button on the player does not turn WHITE, indicating that the storage device is not being indexed.
- The storage device emits repeated clicking sounds but fails to start.
- The storage device does not connect or initiate.
Nope, "it's got to be noise in my USB connection" is the same rabbit hole as jitter. Analog devices can be affected by noise. My house is an example. I live near a radio tower: so most my analog amplifier stages pick up the interference (and I can hear the radio station if I don't have a RF filter). I live in a townhouse that's now 20 years old. It's wired with I think cat5. Just recently I upgraded wifi to 6E. I tested my ethernet off the network switch I have plugged into my house's wiring. It read the max speed of my ISP (getting up to 1Gbps). So even though it would have had a long run to pick up the RF interference, there was no difference in digital bandwith. Conceptually, digital connections don't have to be as tolerant about noise, as they just need enough signal to read a 1 or a 0. There was a sponsor thread I engaged with about a LAN silencer: I wasn't outright banned or posts deleted because I was courteous with an audiophile who was adamant that any noise in a network is terrible for audio quality. The subject was how to test for audibility. He maintained the blind tests had to be conducted with the most expensive equipment and only "audio designers" from that brand. Seems kind of counter productive to the argument that computers (especially server rooms) are "too noisy" as sources, and that audio quality is easy to discern. If so, why not use some computer with internal sound card as source (because it's "too noisy") and sample as many people as you can (because there's not really a golden ear when it comes to any audio perception)?I did watch the video on jitter you shared. It is interesting, and I can see how jitter is no longer seen as an audible source of an error in modern digital front ends that utilize USB or Ethernet for asynchronous transfer of digital signals. From that and other posts here, I am assuming also that the signal from any of the external drives I used was transferred to the Node server asynchronously, so no timing errors were imparted in that process. Other noise perhaps, but not timing errors. But if the Node power supply is struggling to power an external drive, which is clearly a possibility given the caution above, then isn’t it conceivable it could affect the performance of the Node as a server, and potentially introduce jitter and/or other noise to the signal before it is transferred to the external DAC?
During my life, I've had plenty of digital systems with toslink/coax....and I've never actually heard jitter. Practically, the cable run of them in a home system is short so there's not even a hiccup at the start. In real practice when we think of a clock with them, there might be a minuscule fraction of a second before the song starts. Then the connection is good enough that there's not timing issues while the file is streaming.The Node only has one USB port which can function as either an input or an output, and I am using it to accept the signal from the external drive. Given that, the only way to transfer the digital signal to an external DAC is via coax or optical toslink, which as I understand it provides a synchronous signal that includes timing information, good or bad, from the server. Anything that happens to the signal in the Node could affect the signal output via coax, which is what I use in my system.
The video was just highlighting that the $8 DAC (which is not just the DAC chip) was the point in which there's bad enough engineering in the system. So with my systems, the only time I've had an issue with an actual storage medium was the micro-SD slot of a music streamer after a firmware update. After the update, all the songs had popping noises. It was software related effecting that input, and downgrading firmware fixed it. The only times I've heard differences with digital sources is a computer or smartphone going to my Benchmark DAC: the reason not being anything about jitter or noise. The reason being that they may not have a direct API (bit perfect source like ethernet/USB/toslink)....instead first going through their EQ settings.In the video you shared, the $8 DAC highlighted had passible jitter performance but nevertheless the narrator noted it was very noisy in other ways that could affect performance. Is it possible that the Node is functioning more like the $8 DAC than a $500 server/streamer/DAC when straining to power an external mechanical drive, and that could result in audible differences in performance as I have it configured at the speakers/headphones, all other things being equal? I am just trying to see if I am tracking your logic and that I am making my point clearly. I may be completely wrong here, but if so, I want to fully understand why.
kn
