But you've linked to resources from the manufacurer's website that is in no way related to this theory you have that a drive's capacity, current draw, anything under the sun is "the point at which external drives stops" and can actually effect a digital file's audio quality. You're ignoring the manufacturer's description of USB mode settings just effecting number of files indexed, or not being recognized if it's a USB protocol that needs external power. Go back to my YouTube video: it shows you how any USB or ethernet connection doesn't introduce jitter. Noise is another audiophile rabbit hole: I really shake my head at "audiophiles" who will buy a rebranded D-Link $30 router for a "noise isolated" $1000 one. Noise interference works just as jitter: they're both irrelevant with USB connections--in which data is collected asynchronously. Try to think of this logically: these are devices designed to now transmit GBps of data (can be important data for governments or businesses, or for consumers, large 4K HDR movies with lossless 3D audio). You think a 2 channel song (be it lossy or lossless) is really taxing on a system? Since links you've shown don't follow your instincts,
KinGensai's post is basically where this should end now. Show us any measurements that show a true audible difference with USB drives, or it seems you want to go around in circles trying to justify a bias (where you're really leaping beyond logic with the manufacture's documentation of storage format or USB mode that doesn't even mention audio quality).
I have reread your first sentence of this post countless times and I am still having trouble understanding your point. The Bluesound post on the Node says this about “Identifying Signs of an Underpowered Drive”. Notice these are not an exhaustive list of the signs, but rather examples.
Indications of an underpowered drive include, but are not restricted to:
- The PLAY/PAUSE button on the player does not turn WHITE, indicating that the storage device is not being indexed.
- The storage device emits repeated clicking sounds but fails to start.
- The storage device does not connect or initiate.
*Typically, underpowered drives have a size exceeding 500GB or 0.5TB.
I did watch the video on jitter you shared. It is interesting, and I can see how jitter is no longer seen as an audible source of an error in modern digital front ends that utilize USB or Ethernet for asynchronous transfer of digital signals. From that and other posts here, I am assuming also that the signal from any of the external drives I used was transferred to the Node server asynchronously, so no timing errors were imparted in that process. Other noise perhaps, but not timing errors. But if the Node power supply is struggling to power an external drive, which is clearly a possibility given the caution above, then isn’t it conceivable it could affect the performance of the Node as a server, and potentially introduce jitter and/or other noise to the signal before it is transferred to the external DAC?
The Node only has one USB port which can function as either an input or an output, and I am using it to accept the signal from the external drive. Given that, the only way to transfer the digital signal to an external DAC is via coax or optical toslink, which as I understand it provides a synchronous signal that includes timing information, good or bad, from the server. Anything that happens to the signal in the Node could affect the signal output via coax, which is what I use in my system.
In the video you shared, the $8 DAC highlighted had passible jitter performance but nevertheless the narrator noted it was very noisy in other ways that could affect performance. Is it possible that the Node is functioning more like the $8 DAC than a $500 server/streamer/DAC when straining to power an external mechanical drive, and that could result in audible differences in performance as I have it configured at the speakers/headphones, all other things being equal? I am just trying to see if I am tracking your logic and that I am making my point clearly. I may be completely wrong here, but if so, I want to fully understand why.
kn
