derbigpr
- Jan 19, 2011
You sure didn't offend me, and I think your post was quite responsible and topical. Never hurts to have people make me think and less experienced users can benefit from the different viewpoints so I say no worries mate, good points.
All you need to consider is the fact that people who design these amps are not some random guys, they know what they're doing, they're engineers and audiophiles, people who love good audio as much as you and me, on top of that, we're talking about big companies with decades of experience, and a lot of people, money and knowledge that allows them to do far more research and development than say a small company that makes a couple of headphone amplifiers.
If they can make the amps sound great with speakers, what makes you think that they couldn't do the same thing when it comes to headphones? People on head-fi too often seem to act as if headphones are some magical, special, super-complicated devices from the future that take extra special care when it comes to powering them, which is just not the case if you get the basics right, which good sounding integrated amps do. Again, a good sounding speaker amp will sound good with headphones as well, unless they screw up the headphone output somehow, which again, is not the case with any of the amps I've ever tried, for the reasons explained in the first sentence of this post.
What gets most people confused in my opinion are prices. How could a 500 dollar, huge, 15kg heavy integrated amplifier, with lots of functions and purposes, full of circuits and components, have the same quality of components as a single-purpose small 1000 dollar headphone amp that only has a handful of components inside and is only designed to do one thing? Surely the quality of the components and quality of engineering in integrated amps must be horrible in comparison. And the headphone output must be just an afterthought. Right?
You'll find that if you take almost any headphone amplifier on the market (apart from some really cheap ones like O2, Fiio's, etc), especially as you go higher up in the price range, that the price of their electronic components (if you were to buy them separately, especially in large quantities) is a small fraction of what you actually pay for when buying the product, and in almost all cases, the housing of the amp costs close to or even more than the electronic components inside, and a lot of your money goes into covering the cost of R&D, since again, we're talking about small companies that don't have multimillion dollar budgets they can invest into developing a product line. Yes, usually headphone amps are simpler in design, which in theory means that the sound will be less compromised and the signal will have to travel a simpler and shorter distance from the point where it enters the amplifier to the point where it exists. And yes, dedicated headphone amplifiers usually have top of the line passive components on their PCB boards, while entry level integrated amps don't, but do you really think you'll hear a difference between an amp that uses top of the line Nichicon caps instead of top of the line Panasonic caps? You'll probably measure minimal differences if you use the exact same design with different components, but will you hear a difference? That is a big question. And all the complicated stuff like DAC's or pretty much all chips on headphone amps, as well as connectors, transformers, volume pots, etc. are made by the same manufacturers that make those same components for integrated amplifiers produced by dozens of manufacturers from all over the world. As I said again in my original post, what all the integrated amps I've tried had in common was that they got the essentials right...like...no audible noise at any volume, no channel imbalance at any volume, flat frequency response and proper extension in both directions, transparent sound with no obvious coloration or changes in the characteristic sound of a certain headphone, black background, plenty of power, lots of headroom when it comes to volume leading to great dynamics and lively sound with a lot of authority and no hint of distortion, etc. And this cannot be said for all entry level headphone amps.
Is a dedicated headphone amp better for headphones? Yes. Compared to equally priced integrated amps, headphone amps usually have a cleaner design, higher end components, and are engineered to do one thing only. You get the freedom of using any headphone, regardless of impedance, and you'll get (in theory) the same performance levels with all of them. Will they sound better than integrated amps? Depends on which integrated amp, which headphone amp and which headphone we're talking about. I'm sure you're aware that "better" in audio is a very broad term. I'd use the word "different" in this case. But certainly not bad when it comes to integrated amps, and integrated amps usually offer far better value for money. I've heard some really bad sounding headphone amps full of problems like hissing, imbalance, pops / clicks, heating, thin sound, lack of power, etc. I'm yet to hear an integrated amp that didn't get those essentials right. Even my old Onkyo A-8820 (made in Japan around year 2000) that I got used for like 40€ sounds freaking awesome with T1's and speakers and earned a permanent spot in my room, and honestly makes any dedicated headphone amp under 300 dollars I've ever heard seem like a bad joke in comparison both in terms of build and sound. And just look how pretty it is, it's like a match made in heaven for T1's. (yes, this a metal front panel, with metal buttons and knobs, volume knob moves with smoothness unmatched even by my Musical Fidelity M1HPAP, and that source selector has some of the most satisfying "clicks" I've felt in any audio gear, some of us are into that...
