If all you have is a screwdriver, you could go to an extreme and use your soldering iron to make the holes. The excess melted plastic that piles up can easily be removed with a blade and the holes would come out nice and round. It could damage your tip, then again it may not.
Your local hardware store should have small battery powered cordless drills from $15-20 (think 7.2V-9V). Not much power but probably enough for small jobs.
If you have an x-acto knife, you can stick the point of the blade where you want the hole and slowly drill it out by spinning it around. You can also do this with a small sharp knife with a thin enough blade.
