cotdt
- Aug 29, 2005
I used a mousepad. Anything works. The ERS paper is actually not even conductive when I measured it. I put some ERS Paper on the chips because it's potentially a source of EMI, but it probably doesn't make any difference. I would just use it on the DAC chip and the entire back side of the card. I glued the capacitor to prevent it from vibrating.
Originally Posted by jo427 /img/forum/go_quote.gif What did you use for an insulation layer between the ERS paper and the card? Also, you hot glued the Blackgate Cap to the board with a layer of ERS paper under the cap? Did you use an insulation layer there, and everyplace you used the ERS paper? |
