kirtar
- Sep 8, 2008
Top View (really just the components): Here
Diagram (from top view. Shows jumpers, etc): Here
Note: Red X goes to red X, Blue dot to Blue dot, etc. Didn't want to try to connect those dots on the picture.
Okay, so the right side is the V- side and the left side is the V+ side. I hooked up a power supply with red to V+ and black to V- and all works fine, with the VGround being spot on. Then I add the axial capacitors (Nichicon 100uf) as suggested by someone a couple weeks ago (Here) and try again. This time, the caps heat up really fast, so I unplug it. Dunno what caused it, but I have a hunch I hooked up the voltage wrong, since it never happened again.
After letting the thing cool for awhile, I hook it back up, making sure I hooked up the power supply up as explained before, and I have my fingers on the caps and the TLE to make sure they don't heat up really quick. Turns out the TLE heats up a lot after awhile, which may or may not have been a new problem; I didn't check it before since the VGround was correct and therefore assumed I had it hooked up right. Not sure how adding those caps would have screwed around with it though.
Checked for solder bridges, and I did find one, but it's between two already connected pads, so I don't think that's the issue. TLE is in the socket with the dot on the upper left corner.
Anyone have any ideas?
