I can tell you the iphone4 has a pretty good headphone out. But you would need to match it with the right headphones. It's a little light in the bass and vocals are pushed back just a bit. The highs are nice and airy. The iPhone has a nice Wolfson dac, not sure what the others have. The sansa clip is one of the goto portable devices you will see people using here.
Thanks for the heads up. I didn't know that the iPhone4 has a built-in Wolfson DAC as I can't find the description on the Apple website. The Wolfson is good stuff. Since you are using the iPhone, may I ask which headphones you like better with it, the Sennheiser HD-580/555 or the Audio Technica ATH-M50? I am actually looking at the M50.
I just roughly browsed through the Cowon products and although sound quality may be better the build quality appears to be inferior compared to the Apple.
