Home-Made IEMs
Aug 30, 2022 at 7:41 PM Post #14,239 of 15,977
Ok, I did the 2 way with the Sonion 33aj007 and Sonion 2389. Crossover with 4,7uF on a 2389, no dampers 1,5ID tubes. The graph looks like this, what do you think I should correct for that setup?
Aug 30, 2022 at 9:51 PM Post #14,240 of 15,977
by reducing the tube length and bigger ID (2mm) of 2389, you can have better performance at the higher frequency range.
Sep 1, 2022 at 12:46 AM Post #14,244 of 15,977
which measurement standard is this bruv
is it 711 calibrated or some other mic coupler
:stuck_out_tongue_winking_eye:non-standard DIY measurement mic.
calibrate with an oscilloscope and sound level meter.
The mic is from Panasonic, flat respond from 20-16k.
ZEX Pro measurement comparison with 711 is almost the same just no 8k artifact peak.
Sep 1, 2022 at 11:06 AM Post #14,245 of 15,977
Hello guys! I've ordered IEC711 coupler and I'm going to start learning how to tune. What relatively cheap BA drivers would you guys suggest me to start the journey? Firsty i want to do my first single BA IEM of course, what is good to start with? Or some suggestion on cheap options for future 2 way system drivers so i will get all the drivers in one order
Sep 4, 2022 at 5:59 PM Post #14,250 of 15,977
Hey, thanx for all the suggestions, I’ve finished my first stage iem, played a gig with it and I am super happy how they sound onstage. This is how they look and how they sound. 3d printed. I wanted to ask how could I improve the response? I was thinking about white damper on the fulrange 2389 cause sibilants are a tiny bit too sharp. If you got some thoughts, let me know:)
  • Back
