I suppose everyone may do it a little different. However, the SPL curve, for example, is useful in a theoretical sense. it shows the full capability of the unit from a tested and verified source. Once the driver(s) are in circuit, they will all behave differently. This is where driver selection becomes imperative. You have to first establish what your goal for the soundstage will be. Flat eq, v eq, boosted highs, boosted lows, etc. Now we have a target. I start by wiring every driver into their circuit with one set 3x2 tube @10mm in length. I then run spl tests, 8 repetition, with each driver(s) in circuit. Now you can determine if your goal is achievable with the chosen drivers. Many times, ive established a circuit, tested it, and said, “not impossible or improbable, just gonna be way harder than it shoudl be.” Dampers flatten out unwanted peaks, resistors cut some high bite and volume but will push a resonant peak up the spectrum, l-pads lower volume and flatten the resonant peak, series capacitors cut the lows. Personally, Im extremely mindful of the values for capacitors. If they get too big in value AND the driver is pulling major juice, electrical and acoustic phase can get effected. Also to note, acoustic phase almost always, in my experience, is best detected by the human ear.
