mattmatt
- Feb 11, 2012
Its still wired as parallel.But this is a series setup right? Will the series and parallel setup have the same sound?
Series will effect the sound and parallel will also effect the sound. It depends the crossover , the impedance of the drivers , the spl and voltage.But this is a series setup right? Will the series and parallel setup have the same sound?
First image is a first order crossover.Can someone sketch a few options for an RC low pass on a woofer, with other drivers wired in parallel? If all drivers are in parallel, a low pass capacitor in parallel will low pass all of them...
Anyone know a source where I can get Universal empty IEM shells for 2 Pin connectors? I only find 3D printed ones for MMCX. Searching on Taobao does not really yield results, as I don't speak chinese and don't know what to type in
Depends on if it has laquer on, just sand the laquer off at the area you wanna tin, heat it up with your solder iron and push tin against the wire while heating it up, will soak up the tin.Hi again,
Can anyone teach how to tin litz wire cut in half?
First image the fullrange driver is low passed.@Max spl perfect, thanks. I had been trying to use the mid full range (no crossover) so it was also getting low passed.
Yes , for the bass shelf also . The reasons I personally cap all drivers is for the impedance that amplifier sees. All drivers with caps, the amplifier doesn't see them connected all in parallel which is not the best and I don't recommend but each driver has its own impedance at the desired frequencies and the performance of the driver’s increases a lot in compression with non Caped drivers.Edit: I guess high pass on the mid can help you set a nice steep bass shelf, like a Harman curve.
I got the litz wires from soundlink. It's already tinned, however I want to cut it into shorter wires for my crossovers so that the cable/wire management will be more manageable.Depends on if it has laquer on, just sand the laquer off at the area you wanna tin, heat it up with your solder iron and push tin against the wire while heating it up, will soak up the tin.
To cut soundlinks wire isn't possible my opinion. Better to buy shorter wires.I got the litz wires from soundlink. It's already tinned, however I want to cut it into shorter wires for my crossovers so that the cable/wire management will be more manageable.
Oh no, that's so sad. Thanks for the reply.To cut soundlinks wire isn't possible my opinion. Better to buy shorter wires.
Melt solder on solder tip, deep wire in itOh no, that's so sad. Thanks fo
