Hi guys,
Can anyone recommend how to group solder 4-5 litz wires? The qdc type 2 pin is a pain in the ass :'(
You might have better luck making driver assemblies, soldering multiple drivers together with shorter wires, then just take one or two wires to the pin instead of 4-5. You can even b7000 glue drivers together, just make sure you know how they will fit into the shell first.
But to answer the question, solder wires, twist together up to the solder joint, lightly crimp solder with pliers (one time, then again 90* to that) quickly reflow the solder, twist wires tight again, then solder to the pin (with some flux added to the pin so it sticks.)
