Good idea friend, thanks so muchFor lacquering, plug a 2-pin connector into your IEM and you hold this connector with a small clamp, that’s how you do it. I posted a video a few days ago and you have all the clues you need to do an IEM
Home-Made IEMs
- Thread starter Bilavideo
I do not have lack 3 know, i am using cheap UV glue ( not fotoplast) to trial and use this glue to coat outside as lacquer, might be it poor quality and easy return to yellowI want to laugh and cry at the same time. . I went through it all. Stop using a toothpick to close holes when you do lack. The wood absorbs the lack very much and you can no longer take it out. Btw, reduce curring time after lack3 on 4 min. It wan't be that yellow like it is now!
Ok, i will try instead of make a new one, thanks broI will try to glue sharpen stick to broken one inside nozzle. Second way, open faceplate and move stick inside tube by tweezers. Dont worry, repairs and fixing are normal in ciem process building.
Actually I quite rush when use stick because it fit in tube, if have time, i think i can find another way to keep it and dont make this issueI did not use sticks on my builds. Don't you have tube for the bores?
Hi all, I made a new one with universal type, I mixed facelate with color, diffucult to prevent bubble and color is not good dissolve, might be I use poor quality glue and too less, because I just use amount enough for faceplate. But It's look not too bad, : )
dhruvmeena96
Aldo40
Member of the Trade: Alambic-Ears
I order from them , Glue and everything about the shells except drivers.They sell small bottles. The big one are expensive for me .
Where you buy what you need ? Is any cheap internet shop out there I don't know ?
Soundlink
Aldo40
Personally, I take Lake 3 from mcear.Sorry I forgot to write Alternatives to Soundlink .
I know Soundlink years now ! sells only big bottles Dreve fotoplast big bottle 130 Euro + 30 Euro shipping = 160 Euro. Soundlink is expensive shop my opinion.
Dreve is German Company and I live in Germany. If was for big bottles then I could buy directly from dreve or Soundlink and go broke for one costume shell.
The mcear shop sells also small bottles from Dreve and Pro3dure but I don't know if they ship international for those who want to buy small bottles. Something similar to these shops ?
Maybe other companies or other cheap products for small Orders.? Or any other online shops ?
it’s perfect the small quantities it’s ample and yet I lacquer some pairs
With 10ml you can paint tens of IEM and even more!
The UV products do not keep long, I mean by the that if they are too old, they thicken in short I would not buy a big bottle of lake 3, I prefer from time to time to take me small packaging at MCears
TheLastAurora
Hey guys! I'd like some guidance for a project, as I'm a complete noob in the CIEM matter. I know it should be easier to just get a GV-32830, but I don't think I could achieve the tonality I'm looking for. The things that I really care about are note weight, vocals and natural timbre (sub bass is nice too). Which armatures get to delicious mids, good (slightly elevated) bass and non-offendant treble? And how do I set up everything? Thank you!
Total: 8 (members: 0, guests: 8)
