Aldo40
Member of the Trade: Alambic-Ears
yes I read that it’s interesting
1.First add wire to driverHi .
This one isn't for me .
I don't have a ton of drivers ,shells ,and crossovers, i do not have a company to play hours with iems tuning them .
One year took me playing with crossovers and destroying drivers from soldering.
I don't like complicated designs..
And im sure you never had good bass with this one . Im 100% sure . This one never sounded good. No offense. Is Only my opinion
One guy from sonion told me many companies don't use any crossovers and they sound amazing. And isn't a must to use crossovers.
See campfire audio ara or campfire audio Andromeda special edition and many other companies. Many crossoverless designs.
120 db Max 30 khz .
Wiring and driver combination will play a huge role to make the play loud.
The mid driver on andro pre2020You tried the 38dx without a filter to assert that?
I think you have to mount the configuration and make a comparison before being so assertive
As for the use without filter of Andromeda or ambient, I think they use at least drivers that use adequate sensitivities for use without filter. Campfire may also have to make custom drivers for them for this use.
2389D in seriesThx for the info.
I will do same length same diameter exactly the same diameters with this one is preferred on sonions datasheet .
I went with this driver combination because is safe and not complicated. Bass - mid - highs.
The 38D1XJ00 no need dampers.
The 2389D sounds perfectly with a white damper.
Maybe one resistor in series to pull out the low frequency bump ? Or no resistor at all ?
For The est one ceramic cap 2.2uf no tantalum !
One short nozzle with 3 bores 1.5 mm each and that's it .
Is perfect
Also, that's a driver self spec, inside a system with distributed power, you would never hit that number. And also, you might never hear 30kHz.120 db at 30 khz 600 mVrms Burst .
They are latest technology from sonion
This one have improved transformator with 2.5 db added gain
I didn't said 130 db
I meanEST will be in parallel with the other drivers in series.
For the power sharing.
The est needs 4 to 5 times more power than the other drivers to play loud.
I have calculated the impedance and input power of each driver to make them all play loud at limits. is tricky
Aldo40
true
Doing things complicate brings more problems.
I will stay simple.
We all know the disadvantages of the balanced armature drivers. Many companies still use DD drivers and stay simple with best sound quality.
I know isn't easy because the drivers are so tiny and crossovers works well but then is no more space to place all components and I don’t want to end like JH audio with huge shells.
