Hi everyone,
I plan to create a smallest possible crossover DIY hybrid version between the Final Audio E5000 and F7200. Two models that I admire because of their minimalistic design and sound quality. I would like to combine the advantages of a dynamic driver and a armature driver in one earphone. I use a small metal shell where the DD sits, and directly in front inside the nozzle I want to place the BA (without tube).
I already ordered the parts, so it's about to make them match and finding the best solution using the given components. Here some informations about the drivers I want to use with specifications:
Dynamic driver of B&O H5 6.5mm
- Impedance 1kHz: 16 Ohms
- Sensitivity: 90dB SPL +/-3dB
- Flat frequency response: 10-20000Hz
- Power: 5MW ~ 20MW
Knowles RAB-32257
- Impedance 1kHz: 48 Ohms
- Sensitivity: 105.5 dB SPL
- Flat frequency response: 20-11000Hz
This is my first DIY project and If you have suggestions and tips how to pair the drivers, what to consider or you just could refer me a link of a previous discussion, please let me know.
My main questions are:
- Will I need a frequency divider? What type and where to get it?
- Should I use specific dampers attached directly to the BB or any kind of tuning cotton/foam?
- Is there a way to set the volume of each driver separately in a very small shell?
- Should I better make short tubes from both drivers till the end of nozzle and make a seal for a better impact of the sound?
- What kind of mesh should I use?
Thanks for your support!
