12mm long tube, hmmm like suitable, I will try it laterTriple stage damping success 1.
Used an ED29689 and a 2mm ID/12mm tube
Used a white near spout, grey at center and grey at end.
Total damper wise is 1340ohms of damping. But it equates to 1510ohms...which is green damper
It sounds better than stock ED29689 + green(etymotic er4 style)
Its less restrictive and has better high end note compared to straight green damper.
Theory in layman is
Its better to have broken road rather than having a pit..
In detail
White damper near spout dampens the ED29689 spout resonance and driver peaks.. Grey damper at center just rolls of a slight and helps in damping tube resonances..
The last damper perfectly dampens the driver... And also dampens the earcanal sound reflection entering iem nozzle..
Home-Made IEMs
- Thread starter Bilavideo
dhruvmeena96
Is it shure shell...where did you get it from..12mm long tube, hmmm like suitable, I will try it later
Aliexpress shure shell ain't good
yes shure gen shell, I made it myselfIs it shure shell...where did you get it from..
SupremusDoofus
Yeah a scan of the zs3/zs4 shell would be awesomeYes we need a KZ shell 3D scan.... That would be simple game changer
ericj
- Aug 2, 2005
Anyone with a halfway decent camera and a relatively modern computer can do photogrammetry.
Basically you take a whole bunch of pictures at different angles and software stitches them together into a 3d model. And then you have to do some cleanup on that model. Microsoft's free 3d tool for windows 10 does some important stuff, and autodesk's fusion 360 (also free-ish) does some other important stuff. I haven't done it yet.
My research so far suggests that while the "laser" photo scanning systems have a better theoretical basis for a successful scan, at the "less than a hundred bucks invested not including stuff you already own" price point, the laser 3d scanners produce worse results (by a wide margin) than even manual photogrammetry.
Neutral but bass boost from 250Hz is what you need.
ED29689 + Sonion 38D1XJ(subwoofer)
Easy
And will still maintain the 3 driver rule
OK but i want to start with the 3 drivers (per side) that i already physically possess.
dhruvmeena96
HmmmAnyone with a halfway decent camera and a relatively modern computer can do photogrammetry.
Okay...which drivers you have currently....
Can you write to model numbers...or should I find about it..
Westone 3
CI-22955 and TWFK30017
Lemme see
ericj
- Aug 2, 2005
Hmmm
Westone 3
Lemme see
I'll take pics tomorrow. I am reasonably certain that i recall that it's a 3-driver module that Knowles offered pre-assembled, and that it's alleged that the crossover network was customized for Westone.
dhruvmeena96
I know the driversI'll take pics tomorrow. I am reasonably certain that i recall that it's a 3-driver module that Knowles offered pre-assembled, and that it's alleged that the crossover network was customized for Westone.
They are not custom drivers.. They are standard CI-22955 and TWFK30017.
Westone 30 onwards had custom driver and that's the territory we cannot have..
And the assembly is Knowles GK-31732 with one ordinary damper..
What westone might have done is ditching the crossover by Knowles standard and doing there own way..
We cannot discuss that too..
But what we can do is....if you have drivers intact(no harm)...we can measure the TWFK and CI individually and do a dual damping dual tube for even better control on sound profile..
You are starting from the old era basics.. Hahaha...that's also good...
nowadays, all the member starts from buying drivers..
But back in time, all old timers used to reshell..
I did IE8 reshell into some aliexpress custom shell and had foam inside at the faceplate...so the dynamic back wave can be absorbed...
The result was absurd subbass without any change in all other frequency(slightly less mid bass)
I am also from the old era headfi...when they had iPhone type of look for mobile users
Ivan TT
Sooooo....
I removed spouts from my x4 RAB series set + zobel + green damper.
Impressions: almost DD level and quality lows and mids (sweetest mids I've heard from BA so far) but still faster and better resolution of lows, much higher quality than HODVTEC or CI; less distortion; no funny upper-mids resonances, more highs compared to when having spouts on.
While this set up does not have GV's technical delivery or Harman target response it is amusingly musical and has this SLAM!
I hereby name spoutless RABs and RAFs "naked"
And the nature of naked RAB/RAF is quite different, I actually see it almost as another driver altogether that extends a bit more and is not as peaky, I would expect improvement in all recipes that utilise these drivers.
dhruvmeena96
Nice way of removing spout resonancesSooooo....
BigBublik
Hi, guys.
I want to make triple-driver CIEM. I bought drivers - 29689, 22955 and 30095.
Please tell me which crossover circuit to use?
And whether or not to use filters?
dhruvmeena96
I can work on thatHi, guys.
What sort of tuning you need
That would be easy
@ericj @BigBublik
Will work on designs tommorow
BigBublik
Thank you.
I want get more warm sound.
dhruvmeena96
CI-22955 + 10ohmsI can work on that
That would be easy
@ericj @BigBublik
Tube = 20mm length / 1mm
Yellow damper at 5mm away from spout
Followed by white damper
ED29689
Crossover
47uF series(high pass)
470nF parallel(low pass)
Resistor damping= 15ohms
Tube = 16mm/1mm
Damper brown near spout
(How to wire it
ED29689 -> parallel cap => series cap=> resistor damping=> mmcx)
WBFK30095
470nF series High pass
13mm/1mm
Grey damper
dhruvmeena96
@ericj I would like to see your driver pics first
And I have to find Westone 3 already released FR somewhere before we actually continue with tuning
That's why I paused
That's why I paused
Total: 31 (members: 4, guests: 27)
