Ivan TT
Putting my dual RAB’s to a good use...
DaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaammmmmmmmmmmmmmmPutting my dual RAB’s to a good use...
Zobel might be near ~ 2.3uF and 82.5ohmsAre these inair tips? What RAB, what zobel?
https://www.aliexpress.com/item/32832429128.htmlAre these inair tips? What RAB, what zobel?
Get the inductance value of driver@dhruvmeena96 quick question, how do you calculate value for zobel circuit? I wanna use E25ST002, the high impedance one but I see that it has 2 peaks at 3500H and 5500Hz, also a big dip at 8500Hz.
Aint you over damping the mid and treble with lower resistor value.https://www.aliexpress.com/item/32832429128.html
32257 in series, green filter, 56Ohm/2.2uF
I don't think I'm getting full 26dB attenuation, maybe about 18dB but that's good enough for me.
32257 in series interfaces a bit better with usually hi-Z HP outputs mixing consoles have and after all IEM's were initially designed for live sound monitoring, so why not?
I use zobel for the mid driver, so they probably gonna share zobel. Hmm maybe I’ll use first order crossover for the tweeter, gonna try 960nF first because I tried it with the low impedance version of this driver and succeedes@wolkegeist If you use a zobel to equalize the impedance for the whole project, it is best to use only one, and possibly turn up the sound by shortening the tubes, or correct the zobel with a resistor. Adding 2nd zobel (It summing up) to the tweeter will erase the treble and mute the transparency. If you want to align the impedance graph at the top, check out the reverse phase on the tweeter, or use a second order crossover on the tweeter relative to the mid if you have one.
Its better to make a zobel for a driver which you know you can work with or make a zobel of whole circuit.I use zobel for the mid driver, so they probably gonna share zobel. Hmm maybe I’ll use first order crossover for the tweeter, gonna try 960nF first because I tried it with the low impedance version of this driver and succeedes
I dont think RAB-p needs a tweeter@dhruvmeena96 @tomekk @Ivan TT
I’m making a pair of Rab-p + tweeter for my friend. He’s on a budget so do you guys has any recommendation for single tweeter? Sadly Taobao ran out of supply for E25ST.
Hmmmm...Is the Bellsing RAB32277 much worse compared to the Knowles?
I got the Knowles ones for my single BA project a year ago and I liked it a lot for some stuff but... yesterday I dropped the left piece on the floor and now the bass is distorting a lot. I've tried to replace tubes and replaced the damper but apparently, the armature got some damage so time to buy a new one.
Phonak has 10 Ohm resistor wired in series inside the original Y-splitter. You basically decreased your BA's impedance by half.I just mod-ed my phonak pfe(1 BA sonion) with detachable connector. And am not sure if I wired it out of phase. Should the out of phase BA sound fuller(or boomier) with wider soundstage?
