@ForceMajeure
We can use Dayton DATS V2 for measurement
for impedance, voice coil, Thiele parameters, etc
DATS V2 provides the following unique advantages:
•Ultra-linear impedance response measurement for loudspeaker drivers and complete systems
•Accurate measurement of loudspeaker electromechanical parameters (Fs, Qts, Vas, and many more)
•Measurement of advanced Wright Model parameters (Kr, Xr, Ki, Xi) for precision simulations
•Precise, high-resolution impedance response measurements with 30,000 data points (1 Hz to 20,000 Hz)
•Save and compare up to 20 impedance graphs simultaneously within one test file
•Integrated quality control feature set provides pass/fail parameter measurement (QC Pack)
•Sensitive rub and buzz detection functionality reveals hidden flaws in individual drivers (QC Pack)
•Software signal generator with selectable waveform, frequency, and amplitude
•Generates sine, square, triangle, saw tooth, impulse, pink noise, and log sweeps
•Oscilloscope software mode with dual traces, plus adjustable time and amplitude scales
•Oscilloscope and generator modes are compatible with other audio interfaces
•Quality test interface hardware assembled using precision SMT components and automation
•High-quality alligator clip leads minimize contact resistance for improved consistency
•Includes method for calculating Vas from specified Mmd
•Faster-than-ever hardware startup time virtually eliminates warm-up/cool-down
•Software is compatible with Windows XP, Vista, 7, 8, or 10 with no added configuration needed
well any experience builder
i need help
i have SWFK 31736 in 2mm ID/4mm Lenght tube , and i need it crossover in such a fashion that i can have air in Noble Savant DIY build.
savant measurement by brooko on veritas II
it is not calibrated properly but other measurement(other website) shows that savant cannot do a proper 20kHz extension
and some reviewers say that sound stage is artificially stretched as the air in treble is missing
i would be going with 0.5uF, 1uF and 1.5uF as mentioned here in this thread(dont remember which page though)
