Jedrula1
Sponsor: Craft Ears
@Jedrula1 , so I've been doing some research about your problem (and potentially mine in the future). There are all kinds of tube connectors, medical grade and aquarium grade, that could potentially with minimal modifications solve your problem. I have yet to find the perfect one, but here is what I googled and the connectors that could potentially work. I've tried - vynil/silicone/pvc/flexible tubing connector/fittings. All kinds of connectors will pop up, many of which are even smaller than what we need.
Here are some examples:
Number 4, 5, 6 is the type of connector that could work - would just need to cut the ribbed parts to reduce the size of connector. Finding the 2mm ID one might be problematic.
This type works with OD of tubes, this specific one is for 2.5mm OD tubes which is way to small for 2mm ID tubes.
Cool! What is the best way to get this adapters?
I recently made a set of CIEMs for someone with a very small canal. I was able to use some very thin walled stainless capillary tube from EBAY. Used 1mm id for dual bass drivers and 1.5mm id for the TWFK mid/high. Only had to use if for the last 1/2 inch or so. Tedious but worked out well.
And how the FR curves changed after replacing silicon tubes with steel tubes?
Stay updated on Craft Ears at their sponsor profile on Head-Fi.
