I’m not sure I totally follow but if you mean getting as much to come out as possible when pouring it back out, in order for it to be mostly hollow, this is not easy. To get the outer ear thick enough, the inner ear sound port and beyond, was becoming more solid than one would like. This along with static friction and suction effect down inside, not allowing for everything to run all the way back out, I end up with the section from 1st bend to eardrum as basically solid making it very difficult to drill that s-curve. I find it difficult enough to pour excess back out on a fairly straight ear canal. I hope that isn’t too difficult to understand. Any additional information to help me better understand or achieve this?
Thanks
