1. Can you use the same little pots that are used in beauty salons (to melt the wax for hair removal) to melting the krystaloid? ie same pot as i am thinking of getting to melt the wax in
Maybe so. I guess it would depend on how well they control the temperature. The microwave works well though.
2. what quantity of krystaloid do you melt to do one pair of earpieces.
I haven't measured, but enough to come about a half inch over the impressions in the cup. I bought two pounds, and I'd say I'm maybe using a quarter of one of the one pound bags. The good news is that it's reusable, so better to use more than you need.
3. do you coat the impressions with DAP 33 glazing compound
and then dip it straight into the wax bath
and then put them into the krystaloid
My understanding is that it's either or, not both. I've had better success with the compound.
4. Would any of the sunlight cured UV resins be ok to practice with - see link below for example. I can't see solarex available here in large quantities. Only small quantities like 1 or 2 ounce tubes.
Worth a shot, right? My first experiments were with that Magic Glos stuff. Cures well, but yellows really bad.
http://www.ebay.com.au/itm/25-60-10...hash=item1a333838fb:m:m7ZEBbZ6-IC9ACyoPdVC-0Q
