2x DWFK?My question: What kind of mid armature do you recommend? (2xED or 4xRAB?)
But if your choice is ED vs RAB I would take ED.
I do not do with inductors the crossowers, but with resitor (30,30 and 10 ohm potentiometers I will tune)
Check this page: https://www.head-fi.org/threads/home-made-iems.430688/page-265
Make measurements before installation. Last week I was working on a 1*TWFK + 1*CI prototype and without a mid cut-out in CI I had a mess in mid and high tones all the time. 4700 damper itself wasn't enough.
For JH Audio the length is 10-12 mmI see shells with metal tubes at the output ports. I've figured out that the small is for lows and the large is for hi's. Any feedback on how long these are? How about comparisons of with and without them? How do the effect the FR? Is it worth the extra effort?
Thanks
Hi everyone. What temperature that you use for waxing ear impression?
2x DWFK?
BK is very different driver. Cannot be used as straight ED replacement It has different peak placements and typically a roll-off after 7-8kHzWhat about BK vs ED?
Don't know. Never tired combining BK with TWFK/SWFK.Is that a "good" natural roll-off if complemented with TWFK/SWFKs for highs?
Hi guys, im totally newbie here. Little bit confused about choosing the best BA to pair together.
I have some reference like:
CI22955+TWFK30017
CI22955+ED29689
CI22955+ED29689+WBFK30095
Which one do you guys prefer? Or do you guys prefer to use dynamic rather than BA?
but i would like to use BA from Bellsing (倍声), considering it's hard to an expat to get the original Knowles in here (China). Thanks!!
