drumkendrum
- Nov 6, 2016
I ordered this thing almost 7 months ago, so excited it got in. Time to experiment !
I would like crossover for same driver pairing
Luke from Vibrolabs is selling premade kits with Knowles GV drivers (those are combo drivers with a premade crossovers using the Hodvtec and twfk)
You should take a look.
It's not practical to pay $300 for shell I won't use.
Get a 3D printer.
Dear DIY CIEM Community,
after getting into all these things the last 2 weeks, I'm really excited to getting started into this project by practising it in the next few days. Reading all the informations here in this thread with over 400 pages and getting through the very nice made Google Docs Wiki, I think I know now a lot of things making shells, faceplates, designs and ear molds, but the biggest part for me is still making the CIEMs sound good from the scratch.
I know, it's completely a trial and error / measurement and especially experimental thing because the possibilities are endless!
But after reading all this, I found a few different driver setups here (that has been metioned a lot) that maybe are good to start for "beginners". Maybe some of you can give me your advice - or better to say - your experience to the following setups.
The thing is, at the end of the day it's a very cost intensiv thing getting the first good sounding IEM just when you had to build 20 difference combinations before. I also want to fill the complete shell out with Fotoplast, so changing components after that is hard to do.
SINGLE DRIVER FULLRANGE SETUP
- BK-28507 + Grey Damper / SingleTube
- ED29689 + ? Damper / SingleTube
- CI + ? Damper / SingleTube
GK/GQ COMBINATIONS
- GQ + Brown Damper
- GQ (No Damper) + CI (Red Damper) - No Crossover
- GK: CI (No Damper) + TWFK (White Damper) / Dual Tube
- GK: CI (Red Damper) + TWFK (Green Damper) / Dual Tube
- GK: CI (Brown Damper) + TWFK (Grey Damper) / Dual Tube
- GK: CI (Brown Damper) + TWFK (No Damper) / Dual Tube
- GK: CI (Red Damper) + TWFK (No Damper) / Dual Tube
- GK (Grey Damper) / SingleTube
CI/TWFK COMBINATIONS
- 5Ohm on the CI + TWFK (22uF) - No Dampers
- CI (Red Damper) + TWFK (Grey Damper) - No Crossover
- 10Ohm on the CI + TWFK [0,47uF on the WBFK / 39Ohm inline with cap on the FK side]
CI/ED COMBINATIONS
- 10Ohm on the CI + ED-23619 (2,2uF+2,2uF) - (No Dampers)
So the main questions are:
- Which single fullrange driver setup will sound best from the above.
- Which dampers are the best of the single ED29689 and CI setup?
- Will the GQ just with the brown damper sound good enough? How will it work with a CI (Red Damper) without a crossover.
- Which GK Damper combination will sound best? Dual or Single tube
- Will the CI/TWFK Combination make sense, or is it better to start directly with a GQ or GK setup?
- What do you think about the CI/ED combination.
- Which tube lenght's will you suggest for all of this examples to start? 14-20mm?
As I mentioned above, maybe you can give just an addive for 1x Good Single Driver, 1x Good GQ, 1x Good GK and 1x CI/TWFK setup or the best combination of driver and dampers of each "category" of this list to start to beginn. I think this and your answers will help new beginners also to get faster into this.
Much appreciate it! - Thank you!
I'm new to Head-fi. Like many noob's, I have been reading for a while before officially joining and starting to ask questions.
I have not run across this question in my reading, or via a keyword search. I apologize in advance if I am revisiting a pre-existing discussion.
I have a set of impressions, made by an audiologist. They are still "unmodified" in any way. Is it possible/advisable to make a silicone mold of the "original" impressions? My thought process was simply to do this as a fail safe. If I should screw something up while trying to modify to the final casting shape ... I would have a mold to re-create a new "unmodified" set of impressions. Or, I could just use it to create more copies to practice the trimming and modification process.
Any input would be appreciated.
You definitely could make more impressions from your original.
Just put them in the investment cups, pour over them the hydrocolloid let it cool down and take them out of the molds.
Now you only have to use the AB silicone material used to make the impressions, but instead of using it into your ears, use it into the investments.
You could repeat the process a few times so you'll have a few sets of ear impressions to work on.
Usually what people do is once they did the whole process (trimmed their impressions and had a good fitting shells out of them). They simply make a solid acrylic dummy out of those good shells or even keep the original shells and use these shells for every future build (pour the hydrocolloid on them and remove the dummy shells).
GK/GQ COMBINATIONS
- GQ + Brown Damper
CI/ED COMBINATIONS
I just got these fun little things in the mail today.
TWFK's and HODVTEC's - I'm going to try some different crossover configs.
