ForceMajeure
- Jan 19, 2014
18ohm you need to add the cable resistance to it also
1 teaspoon to 30ml of water? No additives for strengthening?Shiloh, I found a viable agar-agar recipe specifically for the negative of CIEMs.
"The usage is very simple, the proportion of agar powder and water, 1: 25-35.
The optimum ratio of 1 and 30. The side thrown into cold water while stirring.
Until completely dissolved, then heated to boiling state is cooled to about 60 degrees on the down mode.
If there will be less water bubbles.
But the cool air bubbles disappear.
Heating pan can also be used directly, or directly with boiling water prepared and 100 degrees, but when reconstituted attention to stir.
Induction heating is disabled, or easy to paste.
Water heaters, direct heating means as heating.
Note Do not paste pot stirred it, then boil it can be used.
Then wait a little to cool to below about 60 degrees can pour the mold.
Useless spent agar can be stored in the refrigerator.
Agar can be reused.
Recommended dug contact with agar resin, or affect the second transparency."
Guys, here is a nice video showing Westone making a custom marble shell
https://twitter.com/eear_takuya/status/785558955057557504/video/1
He sure could waist less fotoplast
Interesting. Are there any pictures of the result online? I was not able to find any.
Just found mentions of new Knowles multi-driver setups in updated earphone doc:
can you link it please?
Sorry, I'm not sure if I am allowed to post it.
Does it indicate whether they will sold as a multi unit such as the GQ and GK drivers.
Well the file says it's confidential...
How can a custom crossover improve sound from the Knowles manufactured one?
I
We are talking about the premade configuration Knowles are currently selling also so nothing much above 2 BAs
