pc27618349
- Jan 24, 2013
I think initially a lot of us love the deep dark bass that dynamic drivers provide. I haven't had luck getting that same sound from BA's and I slowly became ok with that and began to appreciate the bass I was hearing even though it's different than what I was used to. I haven't heard any high end IEMs so maybe you can achieve that subwoofer type bass.
I'm sure the GK crossover question has already been answered already on this forum as to which driver is being x-overed and what the crossover frequency is.
About your tack layer on your shells, I never had this problem that you are describing. It almost sounds like you did the initial cure, the brushed on another coat of gel, put it in glycerine then tried to cure it. That's wrong. You need to do a long cure first to try and catalyze as much of the acrylic as possible before you put it in glycerine. If you're trying to cure a fresh wet layer of gel in the glycerine, you'll definitely run into problems you have described. It did that once or twice and after much cursing, learned that lesson the hard way. What kind of UV light are you using? A handheld LED flashlight or some UV bulb setup? I use both.
Acetone will certainly strip off that tick layer as well as the cured layer. It's powerful stuff. I use isopropyl alcohol but unfortunately both acetone and isopropyl alcohol can leave the surface cloudy which is astetically unpleasing to some. You can get a really nice shine by doing your final coat in gloss and then curing that tack layer in glycerine. At least that's what I do and it's worked pretty well.
After first curing and pouring out uncured material, place it under UV for a 2-3min, then remove the shell from your negative form (avoid touching surface with fingers, use some tweezers) and then place it glycerin and then post-cure for 2-3more minutes. That should solve your problem and should leave no tacky residue.
I see - I think my mistake was pouring out the uncured material and immediately pouring in the glycerin for the post-cure. I thought the idea was to avoid exposing the resin to the air and so any leftover resin left in the shell when i poured in the glycerin floated around and caused a big mess. Thanks for the clarification.
OK guys,
here's the "cool" project... ("super cool" will have to wait till it's measured, because I don't want to put up something that doesn't work)
The design below is quite easy (took me 5min to sketch and it's pretty much bullet proof if you wire it correctly - as in the picture).
First of all I figured if @pc27618349 is using GK why not reuse parts from it, and since the GK is using 22uF cap and the idea is for more neutral sound we can allow for higher resistor lower cap combo for lowpass.
Secondly I provided you with two possible resistor values and cap values to have a bit of wiggle room if you want to add small changes without throwing everything out of order. The same goes for tubing and damper values.
Finally, if R1 value goes up TWFK output will increase, so by increasing R1 you not only move cut off slope back to the left on graph but also decrease the output in that range relative to 1kHz.
If the sound is still too bass-heavy you can put R2 of 20-40Ohms on the second CI (the one w/o lowpass). This will "speed-up" the bass, lower the CI's output and increase relative TWFK's output.
Happy tuning!
Thanks for the design, piotrus! I'll give it a shot and let you know how things turn out. The great benefit of using this clear polycarbonate faceplate is that the UV acrylic adheres enough to keep it on but the surface is smooth enough for me to pop it off for quick access
Do you have any recommendations on where to put the dampers in the tubing? Closer to the driver/away from the driver?
Also, if I'm reading it correctly, you're using one CI at full range, one with a low pass, and what does the cap on the TWFK do?
