pc27618349
- Jan 24, 2013
Nice!! I see you used MMCX connectors of which I'm a big fan. I also some components in there other than the drivers. Did you separate the TWFK and the CI from the GK's crosover so you could position the TWFK down into the canal? That's pretty smart! Some have complained about trying to put double tubes on the GK but because of the lack of clearance between the two nozzles, it's a pain.
I'm thinking Peter's idea is going to do away with the existing crossover and suggest a 3-way, or maybe just add a 2nd order LP crossover to one of those CIs. Either way, a TWFK + 2 CI's has the making of one hell of a great sounding IEM. Can't wait!
Yup! I took the cables from an old pair of Shures that I had and didn't want to invest in another set of cables, so I used MMCX connectors. They seem to be more durable than the two-pin connectors anyways.
I did separate the TWFK from the GK - it was a matter of sliding a razor blade between the two drivers. The epoxy they use to hold them together is quite tough! I had to clean the GK's CI off before I could stick the other CI on it. Like I said before, my ears and ear canals are tiny as heck so I had to find a way to make things work.
I can't really tell what the crossover that Knowles puts on the GK is - it seems like a first-order crossover of a resistor and a capacitor, but I can't tell which driver it is cutting without slicing the circuit board off the GK, which I'm less willing to do.
The bass of a double CI combo has been really good - I've been mostly listening to the bass of dynamic drivers and so I wanted the same impact that dynamics have. It is almost to that level, but I'm not sure if there's some resonance issues but the bass and lower mids are a little muddy. But the muddiness might also be because the TWFK isn't providing the air that it usually would.
As a side note, in making the shells, I've found that cleaning any tacky residue from the shell (I used UV nail gel) with acetone is a much better option than using a glycerin bath to do a post-cure of the shells. Using a glycerin post-cure seems to cause random strands of acrylic to cure in random places, resulting in the gritty texture of my shells. I actually peeled off a few layers of acrylic from the inside of my shell because it post-cured while glycerin was underneath and so there was a very thin flat air bubble along the shell. It also once caused the shells to seal themselves shut (with glycerin inside) because the leftover acrylic floated to the top of the shell and cured there. Leaving the tack for cleaning with a bit of acrylic leaves a much cleaner and smoother surface.
