How can I swap the damper out? Is it reversible? Where do I order from?
yes. You can buy them from mouser or digikey
That's known as an "inhibition layer". Use an organic solvent to get rid of it and follow the instructions.
Do you know any name of the organic solvent that can use?
guys, what is the material used to make the hard shell? (aside from the UV cure-able resin)
Glycerin
Originally Posted by Cryok95 /img/forum/go_quote.gif I don't think glycerine is an organic solvent. The inhibition layer forms on the part that is in contact with the atmosphere. Glycerine is used to provide an atmosphere free environment(i suspect it's probably due to oxygen or smth) so the inhibition layer does not form. That's why some companies use a machine that cures the shell in an inert gas atmosphere to prevent the formation of this sticky layer. You can try ethanol or lighter fluid.
Glycerin is, in fact, organic. I don't know whether it'll solvate the layer better than other solvents, but it is definitely an organic solvent by definition, and is less polar than most linear chain alcohols.
water based emollient.
